The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
This sales man Automatic Pig feeder demo unit came my way.
There is no information on the WWW, so I don't know if it is complete. But I soon found out it had been messed around a lot.
The item on the RHS seams to be a geared timer, it also showed me it was a 240Vac unit.
All the moving parts were taken apart, freed up, lubricated.
It was a good mental work out.
This item should do something, but it seams to have no function. Hence why I think parts are missing.
Even the box was cleaned up.
I got it working.
The horizontal motor turns, the worm gear moves and the cam (RHS) operates the vertical arm(spring one) and this pulls the cross bar.
That moves this drop arm what engages the wheel with the 4 brass studs.
That drives, through 2 gears the feed dispenser. A slotted tube in the brass tube on show.
It even has the feed tray.
