8ob
- Nescient in the vale
too many ugg a dugga's Bob
I reckon you are right, in the wrong hands they are lethal. Think tyre fitters
Bob
I simply can't bring myself to pay that much for a big tin can, knowing my grandparents, and parents, chucked much much better ones.£35 for a new coal scuttle? No thanks![]()
View attachment 420433View attachment 420434View attachment 420435
It was like welding tin foil but got it done and the metal is stronger than a new one would be anyway
What's wrong with a piece of string?I just drilled a hole in the cistern top, fixed a length of fence wire to the plunger top and made a flat hoop for a handle, cos I'm not a savage.
A Hemorrhoid Blue Marina Estate!then @just@ go and pick up a 1.2 x 2.4 sheet of OSB using the trusty workhorse.
In Wales, in an earlier century too by the looks of it...I fixed my garage roof - it was leaking when I got the keys 5 years ago and I’d run out of temporary patches so had to do it properly this time
Old roof held up with pit props, home to several colonies of slugs
Old joists and timber replaced
The main problem was it’s in Wales - and they have folk driving 15mph to avoid speeding tickets in 20mph zones !
I really could do with a “what I fooked up today” thread....
Anyway, a 4 inch slitting saw, scrap. Must be the 3rd one now, ripped some teeth out, lodged in the job. perhaps I need to look up appropriate speeds and feeds for these things....
A magnet type filter is a worthwhile investment, makes this kind of thing a bit easier too.Now winters coming I though I best give the heating the once over, the underfloor heating pump is always temperamental and sticks when not used so Im assuming the water additive is not doing its stuff, being a sealed system and im a cheap skate I just got a ltr bottle, the tubes/bottles with the vent adaptors are 2/3 times the price for less splosh
I thought I had a radiator around with the large style vent plug so I could use a funnel and a bit of pipe but it appears not
Oh well Ill knock the top of the system, take a lock-shield off and wack it straight down a pipe, sorted
200amps and 1mm wire in my MIG and not a bad result
