Yeh ,I noticed the cable on the meterTurn the knob 180 degrees to "200." The leads are in the correct sockets, but the black lead looks like it needs some attention in the near future.
Hold the two probes together to see what the resistance reading is. It should be extremely low. Measure the two pairs of windings.
. Thanks for your guidance much appreciated
See my post #17 in this threadIf you are trying to get the motor running, do away with any other potentially interfering items - like that pressure sensor - for a start. Keep things as simple as possible
I'd rather not have your input thanks ,you always seem to have facetious undertones in your repliesSee his post #35. It might appear that he has ignored your earlier advice
Red to red reads 1.5 ohms,black to yellow 0 ohms . I tried white to black and it read 4.9 ohms.Measure red to red, and black to yellow, nothing else connected.
. I configured this wiring and the motor runs , so does that mean the capacitors are bad ? If I run it too long in this configuration it pops the fuse .Because there isn't oneHow does this work without a centrifugal switch ?
Bob
There are no capacitors connectedIf it runs then no the capacitors aren't bad. Is it working with a load?
The start capacitor in this case is rated 0-40uf, most motors with centrifugal switches have much higher capacitance for the start capacitorHow does this work without a centrifugal switch ?
Bob
Were these readings with the two red, black and yellow wires disconnected from everything else? It's just that you mention white to black and there's no white coming off the motor, white is a capacitor wire?Red to red reads 1.5 ohms,black to yellow 0 ohms . I tried white to black and it read 4.9 ohms.
With a single phase induction motor there needs to be one capacitor connected for it to workThere are no capacitors connected
There is a white coming from within the motorWere these readings with the two red, black and yellow wires disconnected from everything else? It's just that you mention white to black and there's no white coming off the motor, white is a capacitor wire?
