). I used penetrating polyurethane rather than oil, and the old wood soaked up about four applications, so it's well protected. The floor boards were re-nailed with wrought-head nails like the originals. The new light fixtures for the parlors should be arriving tomorrow.That's nothing, Manchester aqua duct from thirlmere runs right through our farm, had a lot more surface water about than we'd had rain one year, called them up, "yes we'd noticed a bit of pressure loss"..!Not personally, but on my behalf - this massive leak on a 3" water main on the farm that we had no idea was there - not on SE Waters plans. Seems to be a branch off a 10" main that we did know about.
Fixed with a bolt on band aid !
You know the rules Dan, No photos and it didn't happenThat's nothing, Manchester aqua duct from thirlmere runs right through our farm, had a lot more surface water about than we'd had rain one year, called them up, "yes we'd noticed a bit of pressure loss"..!
No visible surface leak, so they traced it and found the culprit, their man was happily digging away with a 13t machine till woosh, bucket and boom damn near get blasted to the side, and a 100+ft spout of water appears, they had shut the pipe section in question (apparently about 5 or 6ft diameter!) but because of the sheer pressure and volume still in it it took several days to stop leaking.
They had to import some special repair section from Germany I think... Apparently was losing 1000000 litres of water a day or something daft!
This was pre camera phones and not sure we took any, they were pretty high on security.You know the rules Dan, No photos and it didn't happen![]()
Do not do that.View attachment 414522
think I need to hone the cilinderwall or get a stronger spring. View attachment 414524
What, stronger spring or honing?Do not do that.
This company might be able to help:What, stronger spring or honing?
I say honing but wat I mean is fine emery cloth to smoothen the surface a little.
Spring seems a little weak but to find a fitting one that has the correct strength is going to be a challenge.
from what I can see the rubber seals are worn out. Honing the cylinder with sandpaper is definitely not worth it. Flex-hone for manual work will give the necessary surface cleanliness. What is an amplifier, a pneumatic actuator or a vacuum amplifier, is not so important. If the main brake booster fails, either buy a new one or buy a complete repair kit. There may be wear and tear further down the hydraulic component chain. You need to audit the entire system.What, stronger spring or honing?
Cilinder is depressed (on-off) by a big air actuator so I don't think it is really critical.View attachment 414541
This is an ultra slow hobby machine never going on public roads.from what I can see the rubber seals are worn out. Honing the cylinder with sandpaper is definitely not worth it. Flex-hone for manual work will give the necessary surface cleanliness. What is an amplifier, a pneumatic actuator or a vacuum amplifier, is not so important. If the main brake booster fails, either buy a new one or buy a complete repair kit. There may be wear and tear further down the hydraulic component chain. You need to audit the entire system.
This can cause pain in the wallet.
Thumbscrews abound in yourThe other screws were replaced with brass thumbscrews too.
Consider using socket head cap screw's with a press on knurled cap. Easily squeezed on with a vice, and a good solution for many applications.Thumbscrews abound in yourdungeonworkshop
I've got one of those little linishers, just checked and that fixing point on mine is also missing, shame the belt case door is plastic, as apart from that they are solid little things. Think I'll copy that and replace with thumbscrews - which means I need to buy a knurling tool...![]()
Adding a screw near that dust port firms that cover up nicely. Should help improve extraction too. They're M4 thread.Consider using socket head cap screw's with a press on knurled cap. Easily squeezed on with a vice, and a good solution for many applications.View attachment 414894
I've only seen them in red & black, but I suppose you could touch them up with brass paint.Are they brass?![]()
