gaz1
- westyorkshire
you only need a ft of plunge to work the plunge method as the plunge method will create a jet pressure inside the pipeSorry , I wrongly said bung when meant plunger , 4" plunger wont fit is what I found today...
when sloshed enough push forward and pull back again as you want more water to mix and continue to plunge its hard work but it does do whats needed
pull and replace every now and again with the pig tail and cut/dig in more at the material
as you will know how deep you need to get where the main blockage is
when its clear use the plunger again fill with water and keep filling and push the plunger down this time you use the plunger like a ram/slosher trying to clean the pipes as best as you can do
you can lock it out so it goes upside down to scrap but you need something solid enough on the pull first to then flip it around and you then can scrape the top until its clear then it will drop back down againI like that, wont work upside down , only chuckle Ive had on this so far..
