gaz1
- westyorkshire
send the plunger down firstgot the pig tail on and goes right through , borrowing a bung to screw on tomorrow..
BES.co.uk | Next Day Delivery On 15,000 + Plumbing Supplies
Order drain/chimney rod tools and other drain equipment online at BES.co.uk. Low Prices, Free Next Day Delivery Available, 15k Plus Products in stock. P/N: 13038
bung is used more as testing the width of the pipe
Bailey 94-110mm Drain Test Plug 2 Pack - Screwfix
Order online at Screwfix.com. For use with Drain Air Testing Kit. FREE next day delivery available, free collection in 1 minute.
its used more for testing the water tightness of drains but it can also be used as a width checker dont force it it needs to slide down the pipe easily and its easily trapped if you do force it
this is why you use the plunger first as it will flex enough but use the water plunge method in reverse just fill as much water in that drain as possible as the plunging movement even in reverse can shift and move crap rather well
