Pigeon_Droppings2
- london
Sounds like something that requires an urgent trip to the GP for some sort of topical creamBell bottom piles
.Sorry, I'll show myself out.
.Very nice, doubt they'd do much here other than having me spinning around hanging onto the motorExample, manual drill bits.
View attachment 412587 View attachment 412588 View attachment 412589 View attachment 412590 View attachment 412591
It was an option but they wanted to test 1st..being a tight Yorkshire man I went with digging.A gurt summer house at a clients place was supported on ground screws, never seen them before that but they seem to be common place now.
Bob
I drilled a 24" hole thru clay, blue clay and then shale (had smoke coming from the hole) min. 48" deep, with an auger attachment (rented for $75 a day) onto my small skid loader.No the volume and the surface area are important factors therefore a cylindrical hole has to be bigger than a square hole. If you made a cylindrical hole that fitted inside the square hole you would have a lower ground bearing capacity.
A 450 square hole can if need be be dug with micro digger. Whereas a augered hole would most likely need a 2.5t- 3t machine which isn't often a viable proposition for a back garden
What do you think they use here, then?When I lived in the Netherlands everything was built on piles...even tower blocks
On my building I drilled 12-14" dia holes, and set 8" sonotubes with a re-bar cage & weld on bars on top. Qty (21) of them.I saw for a long time on the net drilling options that expand the bottom of the well. The concrete forms a cushion, with a larger footprint. Prevents pile pulling in winter, good pinching.
"Screw Piles" is the term over here.A gurt summer house at a clients place was supported on ground screws, never seen them before that but they seem to be common place now.
Bob
6000 lb machine. 54" wide or so 48 hp.When you say small how small though. Rear access to allot of UK houses is only around 27in wide. It's why micro diggers are prevalent here.
Although Bobcat makes a 36" wide special just for backyards.
I'm surprised a small micro digger could not swing (and lift) the auger.
Did you consider xplosives ?...![]()
"Think" or "Know for certain" ?I think a micro would spin around the auger if you tried drilling a hole that size.
Age is irrelevant with a digger! Shovels and spades are so last yearI built a steel framed building, dug 3ft long, 3ft wide, 3ft deep holes for the legs to be concreated into
get a bit further along building it and realised my forklift didn't go high enough to reach into the upstairs, I'd already welded my end plates onto the legs so instead of shortening the legs I dug the holes another 2ft deep
digging is much easier when you're young
I guess it depends on ground conditions...if you are close to bedrock then you don't pile do you!What do you think they use here, then?
Talking to a mini-piling guy once he said they do a blow count to judge if the pile friction is high enough. This was tiny piles about 6" diameter that the guy was hammering in with a tubular weight. He cut and welded a point on the first tube then welded on subsequent tubes and kept walloping them down until his blow count was high enough to stop.
