Mines rubbish, phones great, cameras pants.
 The only reason, as I can recall, that I got this phone & archived the Ulefone was simply for a bigger screen.What laser are you using, im blown awayEtching my logo on some bike parts I have made and then said F it, might as well do my calipers
Also tried it on an M8 stainless bolt and it came out ok.
weld some pegs onto the door edge these then locate into the door frame. at least if the hinges are cut it cant be openedFinished the door and hinges today so its ready to paint and then clad with timber
its like buying a forklift, you move stuff you have no need to moveI'm guessing there will be quite an amount of etched tooling in your workshop, over the coming months?
I will do that, we did it on the main garage doors and it would really make it hard to bypass the hingesweld some pegs onto the door edge these then locate into the door frame. at least if the hinges are cut it cant be opened
X-Tool D1 Pro 10wWhat laser are you using, im blown away
You think the engine choice is weird, it’s got Aprilia Mille wheels and forks.Beautiful work on the pipes but suzuki and chopper should never be used in the same sentence we were taught at school.
Here is a better pic of the text on the m8 bolt, capital letters are under 1mm high and lower case under 0.5mm. I am quite impressed especially as it is done on a round part so focus would not have been ideal at the text.What laser are you using, im blown away
I'm well and truly impressed, how deep are the etches? Can they be felt does it rub off?Here is a better pic of the text on the m8 bolt, capital letters are under 1mm high and lower case under 0.5mm. I am quite impressed especially as it is done on a round part so focus would not have been ideal at the text.
On anodised aluminium they can't be felt as they are supposedly just vaporising the dye, on stainless you can feel them and it won't rub off, at least in the short term, no idea about long term.I'm well and truly impressed, how deep are the etches? Can they be felt does it rub off?
Your gonna be the new Banksy of the etching art form.Etching my logo on some bike parts I have made and then said F it, might as well do my calipers
We still use candles up this way.Your gonna be the new Banksy of the etching art form.
The local lampposts will be next!
Modern. You upgraded from wick lamps then?We still use candles up this way.
They are still used in parts of Caithness.Modern. You upgraded from wick lamps then?
