The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Yep, we had one of those too.
They were very common.And us.
But try find one that is a decent price, good condition and is worth investing time into.
Why would anyone want one burning in their home nowadays?
Me don'tNostalgia.
Still got them...And us! we had polystyrene ceiling tiles as well, not a fire hazard at all![]()
my x gaffer sold pink parafin in his shopRemember the 'Esso-blue" ads.
remember the tv advert the pink pongomy x gaffer sold pink parafin in his shop![]()
Is that vertical shaper inI modified a new set of Barkbuster hand guards for the bike I recently acquired. They fit ok, but not entirely to my liking, as when the handlebars are turned to contact the fork stops, the inboard ends of the handguards are almost touching the digital speedo. So, I disconnected the clamps and moved them as far as was feasible up the bars away from it and drilled new holes in the aluminium arms; cut off the excess, and contoured the ends on my die filer. Much better clearance now, so less of a chance of damage in the unlikely event of the bike falling over.
View attachment 410946 View attachment 410947 View attachment 410948 View attachment 410949 View attachment 410950
That's the Die Filer.Is that vertical shaper inmiddle3rd pic? Or equivalent?
Its an Opus 120 Die filer, which I acquire a few years ago. Fortunately it came with a complete set of accessories and a selection roughing & finishing files. Here's a photo.Is that vertical shaper inmiddle3rd pic? Or equivalent?
It's a good interesting indoors exercise to repair all sorts of rotary switches , you might learn easy ways of repairing such things , get a slack handful from a washing machine repair shop to play with ?I think i might have a new one in a box of "useful one day" spares, when it stops heatwaving down I will have a look
I have a nine inch x 6 mag illuminated ring magnifier on angle poise linkage over my lathe chuck area where most turning tales placeI've been after a half-decent Magnifying Lamp for a bit - ideally a glass lens for better optics & less likely to scratch than acrylic.
I found one that was being sold as the connecting section between the heavy base & the arm was missing, & bought it.
It arrived today, so after work I rummaged about for some bits to knock up a way to join the different size base, to the flexi-section on the head.
It's not pretty, but it's functional, & I reckon the magnifier will come in very handy.
The light is good, the head size & lens give a good field of view & depth of field, so it'll be easy to focus & work comfortably.
I used to repair Strowger Telephone ExchangesIt's a good interesting indoors exercise to repair all sorts of rotary switches , you might learn easy ways of repairing such things , get a slack handful from a washing machine repair shop to play with ?
Sleeve or number tag each wire , mark each segment so it can be exactly reassembled easily .
Now digital camera's are here you can afford to take zillions of pictures of links inside the rotator & note from which side is is from
I used to strip & repair all manner of rotary switches with up to six elements & ten or more wired contact points on each element to play with .
This one has 2 led units either side of the glass under diffuser type covers.I have a nine inch x 6 mag illuminated ring magnifier on angle poise linkage over my lathe chuck area where most turning tales place
Lovely bit of kit ,till one day "Clang " which shattered the ring light safety glass cover and put a chip in the lens . It still woks but is a little more open than it was . Next one will be a 12 volt led flood light put on the angle poise linkage or some of these roughy toughy 4x4 over head led Bar lights right across the lathe bed & sod the angle poise & wear my head band magnifier so I will always see what is to the front of me . .
fixed that for you.Also - I don't have a Lathe - but will be getting one soon.![]()
