In Scandinavia the cars are well treated with rustproofing products.Yes, I suspect you are right. This is the first time I've ever seen this effect and the first person I discussed it with was 100% sure it was was a broken ABS ring, but I think it is more likely to be "crud". What I've just found out in the last hour is that the ABS sensor head is all-plastic; the 10mm screw "tightens" down on a plastic flange and I very much suspect that the body that inserts in to the hub is also plastic. This would go along way to explaining the Youtube vid!
No they are a game changer in circumstances like the OP,s....I have a SF and use it all the time.Is this the sort of situation where an induction heater would work? I’ve often seen them advertised but have heard they don’t work well, and are expensive?
Pray tell more - what's an SF ?No they are a game changer in circumstances like the OP,s....I have a SF and use it all the time.
what's an SF ?
Sorry i meant SP (Sykes Pickavant)Pray tell more - what's an SF ?
Thank goodness- I was thinking it may need Special Forces hard nut rather than some hardware
Silly xxxxers ?Pray tell more - what's an SF ?
Why’s that? The sensor itself is likely plastic so won’t heat directly. Or is it the transfer of heat you’d be worried about?Not very appropriate for around a sensor? Might be OK for heating the set screw when just minus its head.
Silly xxxxers ?
No - I didn't miss it.?I wrote ‘around a sensor’. Did you miss that?
I also asked "Or is it the transfer of heat you’d be worried about?" I'm asking as I genuinely don't know how localised the heating is from inductance heating? If you spend minutes heating up the area with a blowtorch, is it going to be hotter and less localised than if you use a 2 second burst of Mig? I thought one of the major advantages of inductance was they get used when you can't use gas.Most sensors are held by a fixing to the side, if using a smaller induction coil you can get the heat really localised. Mine is used mostly for motorcycle repairs where naked flame is far too damaging to surrounding parts.Not very appropriate for around a sensor? Might be OK for heating the set screw when just minus its head.
Yes, the distance is important and the dimension should be listed in the workshop manual. Thin shims are used to adjust the distance.Now, is it the case that some kind of replacement gasket needs to be used to get the correct spacing between the sensor and the ring???
I've just looked in the official workshop manual and there is no mention of shims, but I am sure they needs to be some!Yes, the distance is important and the dimension should be listed in the workshop manual. Thin shims are used to adjust the distance.
