123hotchef
- Kent
Wow I learnt something todayand if the 304 and 316 grade are work hardening, the swarf will be magnetic.![]()
Carbide.What do Masonry Drills have on the tip?.
There are still plenty of good pillar drills made but the quality is reflected in the price.As for Pillar drills, if it's not 40 / 50 years old it's not very good unfortunately.
By which you mean, think of a number, add a few hundred, then triple it!Carbide.
Just got the 99 piece cobalt kit from uk drills, will see how I get onI had an lld Aldi workzone drill press I used for our RC trailer when we raced.
Not very strange but I need to mount a jig to hold some 30mm steel cage clamps. And I needed an extra drill to see me changed the jig..
Some 4.5 Cobalt drills from UK drills and I was amazed they lasted for hundreds of holes at a time.
I did change one or two during the time we had the job running but they seemed to cut no better when new. I was amazed at their longevity.
Using a dealt 18 volt better drill took probably 10 times longer to get through each hole.
I did use a wind up old style scissor jack under the table to stop it flexing but would not hesitate buying one again if i need a small pillar drill.
You can buy drills that are sharpened to cut masonry and steel, I use them to drill out locksi grind all my masonary bits up on a green stone that are impact to a proper cutting edge so they drill through metal and wood as well as masonry
i only use the 6.0mm bosch multidrills and i resharpen them as well before they get 2 worn .there bloody expensiveYou can buy drills that are sharpened to cut masonry and steel, I use them to drill out locks
Bosch Expert Hex Shank Multi-Material Drill Bits 5 Piece Set - Screwfix
Order online at Screwfix.com. Highly versatile drill bits which can drill accurately into hard materials such as tile and granite without skidding due to its sharp tip, advanced geometric design and bosch centring geometry. Made from optimised carbide it can also tackle concrete, brick, wood and...www.screwfix.com
they dont make them a foot long though in 25mmi only use the 6.0mm bosch multidrills and i resharpen them as well before they get 2 worn .there bloody expensive
thats why i sharpen my own up
