If you have a multimeter, there are some very good videos on youttube, search parasatic draw.Starting the Great Fuse pulling expedition today (maybe) or volt drop test....depends on mood.
Thanks, but I know...done that many times (sadly)....sometimes easier just to put ammeter in circuit and wait till the fuse pulled takes it down. Did this after the professianals gave up. If it can't be seen on the the scanner they're flummoxed. Lifetime in instrumentation gives me some edge, but car electronics are designed to retain secrets. Mfrs perks.If you have a multimeter, there are some very good videos on youttube, search parasatic draw.
Basically you measure across the fuse itself.
I had a Datsun Cherry 100A with a dodgy clutch given to me when I crashed my Escort. There was a lid on the top of the bell housing and a plate under the front wing to unbolt to remove the primary gear then you spun the clutch to remove a bolt at a time. Lift the friction plate out and drop the new one in then replace the primary gear and the bolts lid and plate under arch and done in about 45 minutes.Box shape Vauxhall/ Opel kadett from the 1980‘s… easy clutch change without pulling the gearbox and driveshafts out. 15minute job…
The Datsun Sunny (iirc) had that. 30 minutes to change the clutch and that was the first one, never having seen that before.
Yes I've seen them. Thanks.There's some handy charts to cross reference voltage to current across fuses, this is a big pdf so I've screenshot a section.
It's important to get the correct fuse type chart for the mV drop method - it does work well with an accurate voltmenter and has the advantage of not 'waking up' devices on other circuits due to loss of communication (even when the vehicle is 'asleep'). It's also a lot quicker.There's some handy charts to cross reference voltage to current across fuses, this is a big pdf so I've screenshot a section.
Basically anything > 0.0 mV is investigated. Done this before often...doesn't make it less of a b*ll-ache though.It's important to get the correct fuse type chart for the mV drop method - it does work well with an accurate voltmenter and has the advantage of not 'waking up' devices on other circuits due to loss of communication (even when the vehicle is 'asleep'). It's also a lot quicker.
Living the dream?I agree with the original title....I'm still waiting for my flying car:
Thats the way I now fix irritating vehicles, buy a new one, under warranty so its someone else’s problem.Well I repaired the Kuga by buying a 69 reg Hilux
Garage spent 2 hrs (they say) on the Kuga with no success. Might offer it for parts on eBay. Real shame engine was excllent, paint & bodywork good. The AWD is suspect though...might be the rear drive unit that's failed...it would account for the rumbly bearing type noise.View attachment 415433
Only had 2Thats the way I now fix irritating vehicles, buy a new one, under warranty so its someone else’s problem.
A brand new Capri in 1970, a disaster car
Rusting at 6 months old, glue down back of seat,stained to hide, reclining seat collapsed...rubbish build....also the stealership were creating warranty work. They were closed down I think. So many bits not good. Ford weren't interested either. Vowed I'd never buy another Ford. But needs must....Nissan truck electronically died and urgently needed towcar...hence KugaCan I ask why?
I'm rather taken with them btw.
I've had 2 Mk1 Escorts (one of them a Mex), 2 Mk2 Cortina's (one of them a 1600E), and a Corsair 2000E. Oh, and the wife has is now on her second Mk7 Fiesta. Great cars, all of them.Only had 2FraudsFords in my lifetime (74) at 21 with A brand new Capri in 1970, a disaster car and the Kuga another.
What engine is in the fiesta? Some of them have a reputation of being a consumableI've had 2 Mk1 Escorts (one of them a Mex), 2 Mk2 Cortina's (one of them a 1600E), and a Corsair 2000E. Oh, and the wife has is now on her second Mk7 Fiesta. Great cars, all of them.
Triumph 1300 fwd no box removal but 1/2 the internal trim, Vauxhall Cavalier wheel off 3/4 10mm bolts, pull shaft, undo clutch bolts replace 10min on the Scottish one year, never managed it again even in workshop with a clean car and tools laid outI had a Datsun Cherry 100A with a dodgy clutch given to me when I crashed my Escort. There was a lid on the top of the bell housing and a plate under the front wing to unbolt to remove the primary gear then you spun the clutch to remove a bolt at a time. Lift the friction plate out and drop the new one in then replace the primary gear and the bolts lid and plate under arch and done in about 45 minutes.
