Promoted, eh. I suppose he's now in charge of Roger the Cabin Boy.It is.
He's Master Mate.
My water butt has old fire bricks under it (they were free), same tap placement as @dobbslc . The shed which it catches the run off is under a Yew tree so at the weekend I put a lower "total drain" tap in it as the old water in the bottom was a bit smelly, after the weekends' rain it is now full again!
Can you not do a low level connection between the two? Or is that too simple for the situation?I just checked the levels in my two water butts, to find that one is completely full and the other has hardly got any more in than at the end of last week. When I replaced the bricks with breeze blocks, I split the water between the two so they were roughly half-full each - took me ages because I did it by filling a can from the tap, I didn't think of removing the lid and using a bucket until hours later. I've just done the same split again, and at some point I'll have to see why one isn't filling much. One roof is larger, but it's also a poor replacement roof job which leads to any heavy rain running off and missing the guttering altogether. On the other greenhouse, there's no end stop in the far end of the guttering, so that won't help.
I fitted new Bilsteins too - with hindsight, no idea why, as I don't do the miles in it now, as it's a winter hack. But they are perfectly okay in normal use, although I have made some 20 wide collars to sit under the spring mounts to lift it back to standard height - I cracked the V6 front downpipe on my usual commute at my usual speed . . . but I've done two years without working up the enthusiasm to do so.I've ordered a full set of Eibach springs and Bilstein shocks, (B6s) I'll see what she feels like with them and hope they are not too hard.
I really should have held out and got a petrol but I needed something in a rush after getting rid of the company car so just bought what was available at the time.
Sorry, I didn't mention that they on two separate greenhouses - one lean-to on the back of the house, the other standalone at the bottom of the garden. It's not a massive garden and neither are massive greenhouses, but there's about 15' of lawn and a path in the way. I did pick up a kit to join two together, because I want to add one to the other side of the standalone greenhouse, but I can't use it to join these two.Can you not do a low level connection between the two? Or is that too simple for the situation?
Bargain - the Drew Prichard effect has seen most of this kind of thing getting very expensive.Paid £3 for a rusty set of drawers. The pedestal was completely shot, and duly discarded. The drawers were cleaned up and resprayed with a rattle can. Not perfect but good enough for workshop use.
