- Birmingham
Out in fields the last couple days with the flail mower.
Before...
and after...
Before...
and after...
Thats what I was doing yesterday too. Bit of lime on that ground would reduce the butter cups.Out in fields the last couple days with the flail mower.
Before...
and after...
Would that be safe for the horses?Thats what I was doing yesterday too. Bit of lime on that ground would reduce the butter cups.
Not sure….it washes in quite quickly with a bit of rain.Would that be safe for the horses?
Why would you want to reduce the butter cups??Thats what I was doing yesterday too. Bit of lime on that ground would reduce the butter cups.
You would get a better cut with pto powered mower. I have. 23 hp 1.6m flail for the quad, and similar sized one for the tractor....
Acidic soil….by adding lime, you reduce the acidity, reducing buttercups, but this helps other things growing to thrive. So in effect better grass.Why would you want to reduce the butter cups??
shell out and spray the field with selective weed killer. get rid of themBeen a hell of a year for buttercups! Not good for sheep and cattle either so they tend to avoid them too.
They can choke out a lot of the spring grass growth in meadows as well which is very much not good.
Much as I don't like it, it's gonna be a full roundup and reseed on a couple of fields this season.shell out and spray the field with selective weed killer. get rid of them
It breaks up the clumps of horse poo and knocks the tops off the divots caused by hooves in the soft ground, a couple of the corners were still too soft to risk taking the tractor into.what are the chain harrows doing to the ground?
I think this is the cause of lots of leak scenarios,particularly on Brit bikes that are only used occasionally. Use and enjoy rather than show and no go.Woke the tractor up from it's winter slumber today to do some harrowing, found the fuel tap started dripping once turned onI do have a rebuild kit, but would rather rebuild it at home rather than in the field so came up with a quick "farmers fix" of wedging a beans tin under it.
Stopped after about 15 minutes to see how much petrol had collected and the tin was almost dry so I'm guessing the moving petrol had swelled the cork seal and stopped the leak
They average about £2k for a working one here and are so popular there are plenty of aftermarket spares available.I really love those Grey Fergies. Want one so badly for my wee field here in Spain. The perfect tractor, not too big but very capable. And simple (like me)
It was bought to work and is laid up over winter as it's not needed.I think this is the cause of lots of leak scenarios,particularly on Brit bikes that are only used occasionally. Use and enjoy rather than show and no go.
There’s a few around here still earning their keep,the only new replacements are Chinese,can’t imagine they’ll be working in 70 years time.It was bought to work and is laid up over winter as it's not needed.
She'll be 75 this year and still doing what she was designed forThere’s a few around here still earning their keep,the only new replacements are Chinese,can’t imagine they’ll be working in 70 years time.
