JOEPRO
- UK
That'll make the meter wheel spin fast when on full chat! You'll need a hefty supply to run it, probably 40a at least.
I have a dedicated 32 amp supply available in my double garage. So that will serve the compressor I believe that is correct for it.
It is also possible to run one pump or the other with the control box. So when using it for low volume tasks I'll just run it on one pump.
The PO had it running off a single 13 amp fused spur with 2.5 T&E cable feeding it
It did fired up and run OK on that though.
. I was expecting more Gammon, Bacon and Sausages.
