MattF
- South Yorkshire
Am I gonna get to work faster than ever, or will I fall over? Place your bets.![]()
The latter would be much funnier, from everyone elses viewpoint.
It looks like the BT ear defenders are an extra £400They do seem to be the go to for climbing woodchucks around here... Even the groundies use them with the coms/bluetooth in.
Only thing my Eclipse pad saw handle, that I inherited from my dad, seems to be good at, is taking short lengths of hacksaw blade and converting them to ever shorter bitsThe contents of a friend workshop was brought home.
This is some of the items.
Cut on the pull stroke and slow down, they have their uses and when they do, not much else will get the job done. I like mine for cutting into tigh corners in bodywork.Only thing my Eclipse pad saw handle, that I inherited from my dad, seems to be good at, is taking short lengths of hacksaw blade and converting them to ever shorter bits![]()
We have all fallen down with clips even the plate and strap type , ask how I know, the pull is hard to start with but worksBig increase in available power using clipons. your hamstrings will complain for a while.
Biggest advise if you have never used them before is to learn to pedal in circles. as in pull up on the back stroke.
Thanks, I actually was doing that on climbs but I wasn't sure if it was "right". I'd previously been riding with those platform pedals, and steel toe boots, so my seat is too high now, I must remember to adjust it before I set off Tuesday morning.as in pull up on the back stroke.
I didn't fall off anyway (Didn't want to give you thr satisfaction, Matt), it's actually so easy and intuitive to clip in and out, I should have got them years ago.
I actually know a former Team GB cyclist, I might be able to get hold of some rollers...If you can borrow set of rollers, you'll soon here the wir wir wir, as you push more than you pull. you want a constant wirrrrrrrrrrrrr
I've got two sets for saleI actually know a former Team GB cyclist, I might be able to get hold of some rollers...
I used to have the same Bosch multi tool...mine died but turned out to be an easy fix. The motor wires work harden and break which cuts the power....easily fixed.There is another 12 more box's to sort.
Bosch did a recall on them, mine was swoped out by Great mills under the recall.I used to have the same Bosch multi tool...mine died but turned out to be an easy fix. The motor wires work harden and break which cuts the power....easily fixed.
Wonder if I can send mine back...if I can find it!Bosch did a recall on them, mine was swoped out by Great mills under the recall.
Maybe, but you may be a few years to late.Wonder if I can send mine back...if I can find it!
Yes.Gun cleaning stuff?
