Ok I will give it a go, fingers crossed! Onof thats insane!!
Welding a flat plate on a compound curved roof doesn't help. Just using a grit blaster will mess up a roof.Oh dear.... I don't understand what I've done wrong? I didn't get it hot or weld for too long or put pressure on anywhere, the patch is the same thickness as the roof, I'm confused
Battling tops....Welding a flat plate on a compound curved roof doesn't help. Just using a grit blaster will mess up a roof.
I tack without moving the torch and bob about, one each on the sides so it takes forever to do a patch but it stays very cool.
Grind both sides flat, keep the heat out of it with a water spray (Detox sprayers are good)
Use a light hammer and tap lightly and often (steel is slow to move and it's all in the wrist action)
It will be if he cuts the patch out every time the weld shrinks.Sunroof?
