It's considerably dirtier in real life and I wonder if it benefit from a service kit?
Thank you. What normally comes in a service kit for a compressor?Run it & see how it fares. If it's running fine, leave it be, for the time being. An oil change would be no bad thing though, & drain the water from the tank. There'll likely be some in there.
That is a very valid point sirWhich hole? If you mean the dark one at the bottom then yes. How else is the air going to get to the receiver
Thanks mate, I think the best thing is to go to a pneumatic local, I can take it with me then. Is there any special thread paste/lock I should use, cautious dealing with compressed air etc.You’ll need to check your thread sizes, have a look at this one
Air Compressor Valve Non Return Check Valve Spare Parts Tube Connector Tool UK | eBay UK
Find many great new & used options and get the best deals for Air Compressor Valve Non Return Check Valve Spare Parts Tube Connector Tool UK at the best online prices at eBay UK! Free delivery for many products!www.ebay.co.uk
Great, thanks, wasn't sure if some special paste was required.I use this stuff though I bought a single roll, can’t remember where I got it.
PTFE Tape for Gas 5m x 12mm 10 Pack - Screwfix
Order online at Screwfix.com. Suitable for all common gases and liquids. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Thanks Joe Joepro, it's only for smart/spot repairs so should be fine. Need a new NRV 1st!Spraying with a 50L compressor is going to be frustrating at best.
Do also remember to add a water trap some distance from the compressor itself to be effective. All compressors will output moist air and you do not want to be spraying paint with water contamination.
