Dcal
- Antrim Northern Ireland
Today I made a rivet nut setting tool.
I needed to replace a 8mm rivet nut but don't have a setting tool or have much call for one so, I made a quick, simple tool to set it.
Bit of M16 thread bar with a 8.5 hole drilled through it on the lathe and locked two nuts on it.
Squared the ends so the nut would grip and oiled the rivet nut threads and under the 8m bolt head.
Held the 16mm nuts and turned the 8mm bolt with a ratchet spanner and it worked a treat.
I would have struggled to get a setting tool in so I'm pleased with how it worked out.
If I had a small thrust bearing it would have worked even better but perfectly serviceable for a one off.
