he would only have three wheels then.I was under the impression that no spare wheel was not a fail. So take it out.
Check first though![]()
Instead of looking for a matching spare, can't you borrow a full set off another car?
Oops missed that bithe would only have three wheels then.
All together now boys & girls “Three wheels on my wagon & I’m still rolling along”he would only have three wheels then.
But I do have another set of 18s. Given the 18 spare clears the calipers then the 18s may work as temporary swap I'll test fit one on the front tomorrow evening
The last of the 'proper' Minis with the wide 13" Sportspack alloys came with a 12" steel spare wheel which was only to be fitted to the rear which would have meant changing 2 in the event of a front puncture.Not in the same league, but my MG ZS had a standard steel spare that wouldn't fit over the front calipers so if I had a flat front I would have to replace it with one of the rear alloys and use the spare on the rear, luckily I never had to that as it would mean jacking the car up twice.
I'm pretty sure that won't be the only bit of law being ignored, broken etc by quite a lot of vehicles on the road.Their use seems to be misunderstood then…..Ive seen numerous vehicles with them fitted on the road and I doubt it was not under emergency conditions…![]()
I’ve been overtaken by cars with them on!Their use seems to be misunderstood then…..Ive seen numerous vehicles with them fitted on the road and I doubt it was not under emergency conditions…![]()
I was on the M42, going along at about 70-75 & a Volvo estate flew past me at way over the limit with a space saver on the front, woman driving & a load of kids in the back!I’ve been overtaken by cars with them on!
**Language** that!!
I may have been one of them . . .I’ve been overtaken by cars with them on!
**Language** that!!
Many years ago when I had my first integrale, I quickly discovered the standard wheels were a little prone to pot hole damage -mentioned in the magazine long term tests too. I used to come off the ferry in Hull after workign in Germany, drop off the latest bent wheel with Ian Jemison Engineering outside York and continue on to home near Halifax on the 15" dia (same as the road wheels,) alloy spacesaver that was a 135 compared to the 205s on the other three . . . used to occasionally forget and have to slow down again . . .Had this a few years ago when had a puncture and a pre-booked test couldn't cancel. It failed with the following:
Reason(s) for failure
- Nearside Rear Tyre(s) incorrect because tyres with different aspect ratios are fitted on the same axle. (4.1.A.1a)
Yes it would!Put two size matching space savers on the same axle and it would pass!
I would find a way to fail it . or refuse to test it on a roller brake testerPut two size matching space savers on the same axle and it would pass!
