Piero
- Uk
it will blow up before the tanks full ,,, or thermal out trying.
Are you saying i have a large tank ????
in actual fact, I have two VERY large tanks !!!!!!
then dont even think of plumbing in a small compressor ,,, it will expire in a couple of hoursAre you saying i have a large tank ????
Would one of these be suitable for the odd small spray job like a kitchen table set of legs etc?![]()
Low Noise Silent Air Compressor 50L
Specifications: Power supply : 220V 50Hz 1100W (1.5 hp), Oil Free Tank Capacity : 50L Working Pressure : 8BAR Air Flow: 90X2 L/Min Air outlet:1/4 Start instantaneous power: 2520W. Dimensions:670×310×710mmNet weight:37kgwww.aimtools.co.uk
See what their other models specs are. I think they're all going to be similar, whatever brand.
’Low start-up amps” Who is he kidding? He says he already has two very large compressors. Even a moderately sized compressor would likely be a lower start-up drain on the power supply?
I have a lidl mains powered air pump (used to pump up tyres) which I might, sometime, connect to a small receiver and just run it on a 5 minute timer, occasionally. My shop vac is my usual go-to - usually for suck but could, I expect, be used for blow.
Why does a question ALWAYS involve a explanation BEFORE people believe you ???
And there is the single most important piece of information (that wasn't provided initially)I guess I'll have to explain
EVEN though I have two large air compressors, i wish to go more green
I have a solar power station (Anker 767 Inc the extra 760 battery)
I get free electricity from my solar array
So why not use it ????
My power station will only output 2300 Watts
Do you wish to know more????? Or are you happy that I am NOT kidding???
precisely it would have realy helped and saved a lot of worthless postsAnd there is the single most important piece of information (that wasn't provided initially)
If this is the absolute maximum then it may rule out anything with an induction motor. From when I was at college, single phase induction motors need approx six times the run current to get them to start. A compressor may be a bit better as it won’t be staring at full load but something to consider.My power station will only output 2300 Watts
He didn't need to mention setup specifics. The question still remains the same, regardless of application/scenario.
No that could be an expensive exerciseI really would not want to see it smoking
Three times the run current is for three phase motors
Edit see this pdf for Brook crompton single phase motors
