JOEPRO
- UK
I have never TIG welded aluminium before and I am trying to learn myself.
One thing the youtube videos etc do not cover clear enough is the welder settings.
For starting off as a general baseline for thin aluminium sheet (1.2mm) what settings should I use first?
I am confused about the following:
Pulse frequency
Clean area width
Current settings although using a pedal for alu may make this machine setting obsolete
Having severe difficulty getting any sort of a alu puddle to form. Can never see it.
Grey tungsten
Only have a brass or mild steel wire brush. Reading up I think I need stainless?
The filler rod I bought are aluminium 5356 1mm from ebay
Pulse frequency
Clean area width
Grey tungsten
on your machine I can't see a control for AC balance and can only presume it's the clean area width turn it up at least half way if not a tad over without enough cleaning action it will be hard to puddle , have a good scan on YT for AC Balance you'll get it the only other things I could add in general is more rod and you need to move quicker than you think , A good mask is essential if you can't see it you can't weld .
