25.4_mechanic
- Germany, southwest
The design was very closely based on the one from the Hemingway Kit that I'd previously made. I basically just doubled most of the dimensions and then tweaked it for 12 mm silver steel broaches and to suit standard size bearings (as you can't get bearings in exactly double the size of the ones in the Hemingway kit).
To be honest, I'm a bit reticent to share the model or any drawings as it's a blatant knock-off of the Hemingway design (and, for anything up to 6 mm hex, the Hemingway one is probably better as it's shorter and hence stiffer).
OMG my Hemingway shopping-list is getting longer and longer - and I'm blaming you lot for having done that to me
Thanks Al for sharing your solution! I'm motivated like hell
Carsten
