Brad93
- Essex, United Kingdom
The problem with g code, or any type of robotic hardfacing. is the need to alter the feed rate on the fly. G code can be sped up by % i suppose.That's a bit like what I was going to suggest, like an automatic surface grinder where you set stops to limit the travel in one axis and it shuttles back and fourth at some prescribed feedrate and stepover.
A more versatile idea (And perhaps actually easier to implement) might be to buy a CNC control board and generate G code to run the machine as if it were a very big mill facing a part. That way it doesn't need a complete re-design when something other than just a straight sided, solid rectangle needs hardfacing.
It's not the cylinders i'm trying to do.Pick up a used welding robot & positioner?
This is closing up a cylinder on a 1600kg positioner
Or if it's just welding round, torch moved in to position with a pneumatic cylinder
and a simple belt driven rotator
