Kram
- Sussex
Generally means too small depth of cut or too slow feed for your insert or tool.I struggle with chips, mine seem to be long continuous lengths. Sometimes I can get them to break but I don't know why!
Have you a pic of a homemade magnet wand?
Found a pic here, and a few posts down completed. Its essentially a plastic tube with a thin end, and a cap on the other end with a hole. A bit of 5mm steel bar pulls the magnet up and down. I think it was 16mm dia x 8mm magnets, using two of them.
It would be best with a ring to break the magnetic connection as the magnet is pulled up, but I generally use my hand or a cloth while holding it over bin.. having a ring would stop it fitting into the small areas that make it so useful.
Stuff you have made today
I made 3 different sized pipe stand offs to get around the posts in the wall and then got my new hardline installed. Good setup on the lines, but is that footpeg a styling upgrade :D
www.mig-welding.co.uk
then milled the hex on the Chiron.
