The customer is always right...unless they're wrong, obviously.How so? Extra work = Extra £££££, surely?(Actually, I quite like it, it's.....different from all the other gates.
What an amazing bit of kit, I should have got one years ago.
My renter dropped this off, and asked me to drive it, as he was busy.Yeah 8 furrow, have a NH 7.270 on the front, we'll weighted up. In light sticky soil the slats don't trail soil as bad as a solid board, in the autumn on stiffer land like the photo the slats generally break it up a bit more so making it easier for the drill. We only have disks on the back furrow, ive never saw a plough with full disks round here.
T'would be amusingly nice to take that down town shopping and see if they can put a wheel clamp on the motor because you are a few inches over the line into the next parking bayMy renter dropped this off, and asked me to drive it, as he was busy.View attachment 383430
Yes, unlike a regular dozer. It has a steering wheel, and a single brake pedal.It's a strange experience driving one of those.
Made mostly last night, finished off deburring/cleanup today.
No reason, just fancied making one.
????I'd love a dual extruder.
I've use wood templates with great success with a plasma - for a quick and easy template for limited use they work well. Admittedly after a few uses, they do seem to smell a bit singedThen I had a brain storm, why not cut out between odd leg calliper scribed lines in 1/4 " scrap strip wood allow a few mm for the nozzle diameter and give it a go with it securely clamped to the bracket .... in the right position .
I chicken'd out did a tria;l burn out on a bit of the same metal scrap. Wow worked better than I'd hoped .
Third bracket is a lot better hardly any filing to get it rectangular
Forth bracket was even better , next time I'll run some 2" x 1/4 inch thick oak strips up on the bench saw make a strip for the spacer gap in the slot as wide as the slot I want then glue them up , leave to set over night in the airing cupboard and then use the mask of wood for plasma hole cutting the next day . I reckon with a few experiments and making the cutting slot just a tad bigger than the diameter of the nozzle I might be looking at 2.5 mm wide straight slots in 5 mm alu.
I dare say I could have purchased the brackets and clamping parts from somewhere after doing a few hours online searching but where is the fun in doing that and paying for them at the same time ?
View attachment 383503View attachment 383504
Never thought about such lightweight gates but i suppose that is the way to do them.I hung the arched braced gate ,featured on these pages a day or two ago.
I’d welded it 15mm out of square ,to allow for sag,it hangs perfect and levelView attachment 383506View attachment 383507
I use hardboard templates. I have various sized circles, squares and even long straight lengths. Seem to last ok.I wonder if thick hard board is any better or some of one of the thinner heat resisting soft files , such as go behind boilers etc. in stud walled internals
