I just had a word with Sooze, she told me that it is a motorcycle type for just that reason.A motorcycle based trike is one with handle bar steering, but the weight also comes into it. You only need the double headlight if its more than 1700 wide.
Even on the Trike MSVA Facebook group there is very little 'knowledge', just lots of guesswork. I'm not sure how many of the members have ever actually put a trike through MSVA.![]()
From that link.A lot of these trikes get registered "disabled" and circumnavigate all the rules, as in there aren't any. They then go for a taxation class change after registration, job done.
Bob
From that link.
There are also some sad people out there who think the dispensation within the MSVA for a disabled rider is a loophole to be exploited. This is well out of order and in fact is a criminal offence. Supplying false information on the declaration you sign is in fact fraud and you will be prosecuted if caught out.
Very complex but none of it applies to your build.Mirrors, dead simple, make sure you can see behind you, for your own safety.
One of several pages of MSVA mirror regulations and parameters...
I know, I was just giving an example of the complexity it can go into.Very complex but none of it applies to your build.
Re-read my post, following that would show that section 3 (which you have quoted)does not apply and you can ignore it.
Section 2 is what you want and it's all pretty straight forward.
That complexity is explained clearly on the page previous.I know, I was just giving an example of the complexity it can go into.
Not much has changed since I built the last one 13 years ago now. Sooze is superb, not sure if she still has contact with the guy who wrote the manual.A lot of these trikes get registered "disabled" and circumnavigate all the rules, as in there aren't any. They then go for a taxation class change after registration, job done.
Bob
I'd have had the issue of connecting a belt drive to a differential then, but if I'd know it was available I'd have built a V8 bike instead.Just found this thread. Cool stuff..... if I had found it earlier I could have offered the planetary box from a Boss hoss to keep it short.....belt drive unit. Slipping clutches but still of use to someone building a Chevy based trike. I changed it to a powerglide 2 speed. Engine was a 502ci.View attachment 382170View attachment 382171View attachment 382172View attachment 382175
