MattH
- Cornwall
My small 1kw fibre laser will cut 10mm mild with oxygen.
On nitrogen it will max out at 5mm stainless and 4mm aluminium.
For 10mm stainless you’d probably need a 3Kw at least, that’s a lot of money.
Most of the big secindhand lasers are C02 resonators and you’ll need higher power to cut the small thickness as a fibre laser.
My lasers have a cutting area if 1300mm x 900mm and weigh about 2 ton each so your not pushing it about on casters.
