MattH
- Cornwall
My small 1kw fibre laser will cut 10mm mild with oxygen.
On nitrogen it will max out at 5mm stainless and 4mm aluminium.
For 10mm stainless you’d probably need a 3Kw at least, that’s a lot of money.
Most of the big secindhand lasers are C02 resonators and you’ll need higher power to cut the small thickness as a fibre laser.
My lasers have a cutting area if 1300mm x 900mm and weigh about 2 ton each so your not pushing it about on casters.
. Ok for some things but others not so good. I have a pneumatic scriber on my plasma and it is wonderful for setup lines bend lines etc. So anything I get needs to do the same, when you get spoiled, however it is actually very wonderful. I have a nitrogen generator, but from what I have discovered the operational pressure depends upon the thickness and my pressure is too low. So
