think you are right on the sleve its also for the movement of the pipe in heating up and cooling down as that would rub on the wall, of the pipeI have heard suggestions on a number of occasions that copper can react with concrete, so should be wrapped in a suitable plastic (PVC would probably be unsuitable).
it saves you earth bonding the water from stop tap to electric service supplyyou cant bond plastic
.everything should be rcd protected though
There is some shocking copper about, only buy quality or you would be better off with plasticI have noticed modern copper pipe seems less coppery and thinner wall section than pipe of old?
if all the pipes were copper you would bond all the metal extraneous parts so there all at the same potential. less chance of getting electrocuted including metal handrails windows steel beams the list goes on. it was called the silly season . fitting an an rcd on the supply eradicates the need apart from you still need to bond incoming supplies gas water and oil lines that are metal entering the buildingWhat on earth is the point of those bonding wires???Box ticking?
I did a bit of gas piping in Portugal. The copper pipe came with a PVC sheath. Rules were very strict out there after a British paper ran some stories about CO accidents with gas heaters and other problems. No hidden joints in walls and all hard soldered. Walls and floors were all concrete or brick, so corrosion was def a risk.I have heard suggestions on a number of occasions that copper can react with concrete, so should be wrapped in a suitable plastic (PVC would probably be unsuitable).
The stuff you get these days is terrible...I've even switched to using copper olives in compression fittings as I found the brass ones easily score the pipes because they're so thin.I have noticed modern copper pipe seems less coppery and thinner wall section than pipe of old?
Plastic has been around for a long time mate.youngsters are in the plastic camp. old timers that have been around are for copper tried and tested
I'm 62 and been doing this since about 83.... the rest of you must be really oldyoungsters are in the plastic camp. old timers that have been around are for copper tried and tested
neverPlastic has been around for a long time mate.
Don't be obtuseneverremember when they brought it out for heating 53 years ago and it was ****e . after a few years it had to be replaced
it shrunk went brittle and leaked im 68 and started work when i was 15
