Pigeon_Droppings2
- london
I'd add composite joists to that list too I think!2 things are crap in houses plastic pipes and chipboard floors
There has been plastic for 30+ years, yes you will get stories of failures and doom but badly fitted copper is just as bad as badly fitted plastic
I know you said leave it aside but the difference really is time and money, copper is expensive and slow, plastic pipe is cheap, good fittings are expensive but it's fast to install
All things being equal, I would want copper in my house but I would use plastic where it was suitable
I have seen a 54mm elbow blow off a boosted cold pipe, but it doesn't put me off copper in general, same as the odd failed plastic fitting I have seen doesn't put me off plastic
I have noticed modern copper pipe seems less coppery and thinner wall section than pipe of old?
I'd mix and match personally. Long runs from a single plastic pipe makes more sense than multiple joints.
The largest copper pipe I joined was 76mm. I had to cut it in two places to change a feather washing machine. The solder fittings come in three parts with a tinned cone that goes over the pipe and into the coupling. I had never done one before. Had to use oxy acetylene to get it hot enough. I had all my fingers crossed when I very slowly turned on the 5bar supply to it. But luckily it held.I have seen a 54mm elbow blow off a boosted cold pipe, but it doesn't put me off copper in general, same as the odd failed plastic fitting I have seen doesn't put me off plastic
proper plastic systems are 10 barQuestion:
How common are roof tanks in UK nowadays?
Here and in Spain and Portugal, houses run direct off the supply. So the push fit stuff that I understand is common in UK is no use here.
Not checked the pressure here (plenty) but my last place down south was 5 bar. In one local village, it was high enough to dribble PRVs on hot water cylinders, so they had to fit reducing valves on the inputs.
That’s a proper politician’s answer
youngsters are in the plastic camp. old timers that have been around are for copper tried and tested
still learningWhat does 22 years in the trade make me? Far from a youngster but I'm not stuck in the past
try 52 years and still dont know it all
still learningtry 52 years and still dont know it all
One small thing to factor into your choice is if a significant portion of the pipes will be exposed. For anything meeting that description, I would go for copper. It just looks neater as it is straight, end feed fittings are small and it is more robust.
Edit:
As you say you are remodelling, plastic can be very helpful as it is flexible. You can poke it through a smaller opening than a rigid 3m length of copper tube. You can feed it through a series of joists. Also, copper is only available in max. 3m lengths, so if you need to run more than that, it needs to be joined. A coil of plastic pulled through could save making a hole in a difficult location.
Going back a bit, there was some grief about peeps using copper destined for gas, as opposed for water. Apparently, the gas stuff had impurities that corroded it when used for water. Need to be selective...
KF
