Dr.Al
- Gloucestershire, UK
Yet another box
Padauk, maple & lead. The lead is hidden inside between two maple "bases" (upper one visible in the next photo) and makes the box heavy so it doesn't move around easily. It's for my bedside table and I want to be able to open it in the dark without inadvertently knocking it off the bedside table.
The lid hinges on some pins that go into brass bushes:
The lid was originally fitted at the same time as assembling the dovetails (for obvious reasons), but I'd been an idiot and fitted the brass bushes on the end that I hadn't shot square (as I was expecting to trim one end to length after fitting) and as a result the lid was slightly wonky. The only thing I could think of to do to fix it was to cut the old lid off and make a new one with sprung pins (using the spring from an old pen with a little brass piece on each end to bear against the two pins). Hopefully once the process of oiling the box is finished, I should be able to fit the two pins , squeeze them into the lid and then push the lid into place.
