Guineafowl
- Inverness
I’m getting a TS light vertical in the next few weeks, fitted with single phase motor and starter. I’d like to run a 3ph with inverter so there may be a chance of swapsies, if you’re interested.
you have changed your mind that many times your confusing me..anyway step back here as plenty of good advice floating aboutRoofman was confusing me. nut all good know as below my reply to Geoff
I have a chance at a Transwave, just checking on price he wants for it.
If not then i am getting this so kit can wire straight to the .375KW 3 phase star motor i have
AT4-2200X Variable Frequency Drive Converter Single Phase Input 3PH Output 2.2kW | eBay
Power Phase Number: Single Phase. 1 Variable Frequency Drive Converter. Maximum Output Frequency: 400Hz. Output Mode: Three-Phase 380VAC Output. Filter: Without Filter. Application Range: Universal.www.ebay.co.uk
when folk say do this do that and get so many other ways to go then somebody says different its not easy when you have little idea on it. good to have many ideas from folk but all need to be looked at the best way to go for me.you have changed your mind that many times your confusing me..anyway step back here as plenty of good advice floating about
whats the reason for you going 3 phase kida. better to run off inverter for speed control ?I’m getting a TS light vertical in the next few weeks, fitted with single phase motor and starter. I’d like to run a 3ph with inverter so there may be a chance of swapsies, if you’re interested.
I have three phase, but would still run through a VFD.whats the reason for you going 3 phase kida. better to run off inverter for speed control ?
i am still waiting on a price for the Traswave to run my 3 phase. but i will later get a small VFD for the mill as its a small motor. Although if the Transwave ends up being daft money ill be getting the VFD sonner. cheers though for the offer kidaI have three phase, but would still run through a VFD.
No probs. Not a proper machine unless it’s three phasei am still waiting on a price for the Traswave to run my 3 phase. but i will later get a small VFD for the mill as its a small motor. Although if the Transwave ends up being daft money ill be getting the VFD sonner. cheers though for the offer kida
3ph is smoother than 1ph. You can also adjust speed while keeping the Torque.
Energy wastage - when motor is not running - is much lower (especially compared with a rotary converter).What other advantages could we list? Please add to this list:
Speed can be increased over that provided by mains frequency.
Soft starting (ramp up the speed), so less likely to trip a breaker.
No issues with multiple stop-start or forward-reverse cycles.
Electronic braking, so can slow down faster than just coasting to a stop
Control circuit of VFD is all low voltage, so easier, safer and more versatile.
Better surface finish: I had a Colchester Student which came with its original 3-phase but had had a single-phase motor fitted.Energy wastage - when motor is not running - is much lower (especially compared with a rotary converter).
Emergency stops are all low voltage circuits.
Torque pulsation, I expect. The only real advantage of a single phase motor, is that you can use it on single phase.Better surface finish: I had a Colchester Student which came with its original 3-phase but had had a single-phase motor fitted.
I kept getting a strange patterning on turned parts; tried all sorts to correct it but it only stopped when I put the 3-phase motor back on.
Please don't connect that up! At least not until you've drawn up and photographed your diagram, I have serous doubts about what you've done there....Just need to check before I blow myself up lol.
So 240v single phase tp output of 3 phase motor
The motor has this wiring coming out the switch. 3 in the motor.
Have my VFD to wite up. Blue goes in W1 Brown to V1 and both the Black go to U1 ?
Wire out the motor
Out the switch
And instructions
View attachment 375911View attachment 375912View attachment 375913View attachment 375914
