To be honest I thought you had to use them doubled up as that is way I have always done it?When I fit the strings I always push them in folded in half so when I pull the tool out there is two bits of the string in the hole with a loop inside. With the effort involved to get them through like that I can't ever see them coming out. I've taken quite a few tyres off with them and there is always a nice sticky blob on the inside.I have seen people stick them so there is only one thickness in the hole.
I've used them on a JCB Loadall tyre that had run over a piece if steel sticking out of the ground in a gateway. The tyres were due to be replaced but I think we 8-10 strings in the hole and were able to pump it up enough to get home.
Basically an old tyre carcasse that's worn out, then had new tread glued on.But a re-mould is a used tyre !
I'd never buy either because I've seen far too many re-mould crocodiles & black hoola hoops by the side of dual carriageways and motorways of the UK, Europe and elsewhere.
I can't see any other way to use them.To be honest I thought you had to use them doubled up as that is way I have always done it?
It’s possible to push them in so only one tail is sticking out. I always thought they should be doubled too. When you pull out a nail or screw jam one in with two tails sticking out I cannot see how it’s ever coming out on it’s own.I can't see any other way to use them.![]()
As well as parking up with a flat for a long time such as a month or so or parking on hard standing with a fully loaded truck for a long weekend then driving off not having checked your tyresthe other thing that can cause that is driving on a flat tyre
All at full pressure on drive axle 90psi 295 tyres, it was happening to the NSR inner tyres only and only on the 63 plate motors, we never did find out why and it has not happened again, after about 30 odd had the same fault over a few months.the other thing that can cause that is driving on a flat tyre
Stress on the tre because of the lenght of the lever age after the dolly pin inthe turn table going round alot of mini round aboutsAll at full pressure on drive axle 90psi 295 tyres, it was happening to the NSR inner tyres only and only on the 63 plate motors, we never did find out why and it has not happened again, after about 30 odd had the same fault over a few months.
Do drivers not do a walkaround inspection before setting off?Truck remould failures caught at inspection time, next time you are trying to save fuel by matching the trucks speed, think of these tyres and bugger off asap!View attachment 375255View attachment 375256View attachment 375257
looks like the first group was either inside on a single wheel or on the facing sidewalls on a twin?Do drivers not do a walkaround inspection before setting off?
Mainly facing sidewalls, but have had some on the inner tyre inner side only.looks like the first group was either inside on a single wheel or on the facing sidewalls on a twin?
..........could not undo the wheel bolts. I kid you not.
