I am in Chippenham, using yours would be good but really need to invest in something I can have on hand
How do they attach the coil to the board?
Already offere a hobbyweld bottle - what more can I do ?The deposit on the oxy bottle was the one that made me wince the most.
I know conflicting advice is a pain in the **** but you could heat with that. It is a cutting set but it will heat well until you pull the oxy lever to cut.So is this the kind of kit I need for just heating things up using oxy propane?
Oxy/Propane 18/90 Cutting Set
Contents 2 x Regulators (Oxygen & propane) NM 18/90 cutting torch 2 x Flashback arrestors (oxygen & fuel) 2 x Hoses Nozzle cleaner 2 x Cutting nozzles Combination spanner Single flint lighter Tool casewww.weldingsuppliesdirect.co.uk
Apologies i replied without thinking, I see your in Bristol so not too far. Pm me what you would like for it and where in Bristol you are and we can sort something outAlready offere a hobbyweld bottle - what more can I do ?![]()
I don't know how the cheap handheld induction heaters hold up with multiple heats, but the one I use at work is water cooled and if I really hammer it, it overheats. I also don't know the economics of induction heaters versus gas is, but for heating bar I use the induction heater pretty much every time over the forge or oxy/propane. The heats virtually instant and there's no messing about relighting the torch constantly or wasting gas leaving it lit
Depends how good / confident you are with a torch. If you are doing 20mm bar that will get it hot in a good time in a localised area.
There is the option of a welding torch or a rosebud but for heating big stuff I just use the cutting one as above.
Depends on your budget. If I was in your shoes and was going to buy one thing for heating 20mm bar I would use that. The bottles etc are the pricey bit. You can always add another welding torch if you want to heat small stuff or braze / solder things.
Edit. : some bedtime reading http://murex-welding.co.uk/gb/en/support/upload/A5-Safe-use-of-Oxy-Fuel.pdf
Not being rude but I hate them!!!My torch has interchangeable ends beyond the valves, so I can have a cutting torch, a heating torch or a soldering torch with just a few seconds of changing the end.
I thought they were all like that.![]()
Yep - my first one, a cheaper one, let all the magic smoke out one evening . . .Same as cheap welders, you get what you pay for. Send the right money on the right tool and it will run all day.
I can see how that might be the case, I basically only use mine for heating but it's nice to be able to cut if necessary.Not being rude but I hate them!!!
I’ve got different torches. Easy to swap the hoses. Just personal preference but if you’re burning a lot then I find there’s too much to get caught
OP - if you want this it’s yours for the postage. You’ll need nozzles. It’s butbro so not ****, just unused.
Not excessively so. Depends on the size of the bottle to some extent. Bottles are portable.
With the induction heater, far more of the energy is going into the work piece. It is the only thing that is being heated. That said, commercial leccy prices are likely much more expensive than bottled gas, so economy may come down to how much material is being heated over a long period.
Here is a domestic analogy: My gas boiler is likely no better than 80% efficient (without considering other system losses) and it only heats the whole hot water cylinder (from the bottom), whereas just heating the top section of the cylinder (a short top-fitted immersion heater) with more expensive electric (100% efficiency) can be less costly - especially if of most the hot water cools down.
At E7 rate, leccy pricing is not that much different than gas for that duty - with only the two of us in the house - whereas a family of five, requiring hot water throughout the day would fare much better with the gas boiler rather than my daytime electricity rate (being nearly 4 times as much as gas).
The current one I limit its use to close to the instructions duty cycle.
