ajlelectronics
- Gloucester, England
As detailed on another thread, I am working on a surround amplifier that has been got at in the past. It has been taking out its power transistors on the front left and front right channels, seemingly at random although all Voltages are in sensible figures. I have a new set of expensive transistors in there now and am trying to set the idling current. This is done by adjustment of the trimpot to achieve a Voltage of 6.5mV, waiting ten minutes and then setting 8mV. This is specified with no connections anywhere, to anything. The interesting point is that there is no Voltage being developed at all, which tells me that the output transistors are not pulling any current. I have tried two other Voltmeters plus my 'scope. The circuit diagram is particularly unhelpful in terms of Voltage readings so I am scratching my head a bit.
Before the last transistors died, I did have an amount of wooly audio from the front channels with the volume set flat out, but nothing like what would be expected. Circuit of one channel below. The test voltage is across the emitter resistors, via a 10K to TP401. I have plus and minus 60V DC being supplied to the PA board.
Audio Section
Adjusting Idling Current
Required measurement equipment: DC Voltmeter
1. Preparation
(1) Temperature should be at avoid direct blow from an air conditioner or an electric fan and humidity should be moderate,
and place the set at normal usage environment.
15 °C ~ 30 °C (59 °F ~ 86 °F)
(2) Presetting
• POWER (Power source switch) STANDBY
• SPEAKER (Speaker terminal) No load
(Do not connect speaker, dummy resistor, etc.)
2. Adjustment
(1) Remove the top cover and set VR401, VR402, VR403, VR404, VR405, VR406, VR407 on at fully 7CH AMP UNIT at
fully counterclockwise (c) position.
(2) Connect DC Voltmeter to test points (FRONT-Lch: TP401, FRONT-Rch: TP402, CENTER ch: TP403, SURROUNDLch:
TP404, SURROUND-Rch: TP405, SURROUND-BACK Lch: TP406, SURROUND-BACK Rch: TP407.
(3) Connect the power cord to AC Line, and set the power switch to "ON".
(4) Presetting.
MASTER VOLUME : "---" counterclockwise (c min.)
SPEAKER (Speaker terminal) : No load
MODE : MCH STEREO
FUNCTION : DVD
(5) Within 2 minutes after the power on, turn VR401 clockwise (x) to adjust the TEST POINT voltage to
6.5mV ± 0.5mV DC.
(6) After 10 minutes from the preset above, turn VR401 to set the voltage to 8.0mV ± 0.5mV DC.
(7) Adjust the Variable Resistors of each channel in the same way.
Audio Section
1. Preparation
(2) Presetting
2. Adjustment
(4) Presetting.
MODE : MCH STEREO
FUNCTION : DVD
6.5mV ± 0.5mV DC.
