Myles1970
- Monaghan, Ireland
You do the best job you can do within the limitations that are set for you. I’ve steered away from lap/joggled joints, but I have the luxury of an enclosed garage and I’m not under pressure for time. IMO the pinnacle is tig welded butt joints, but as of yet I don’t have the skills (or the patience). I may be prejudiced against lap joints having seen the results of lap welds (they may have been plated repairs) where the hidden excess metal has corroded unimpeded. There are many spot-welded seams in the average car from the factory, but these always seem (see what I did there) to be the first places to rot, going largely unnoticed - it’s not until the paint starts bubbling in plain sight the the owner takes action.
Anyway, this is your project, and your keeping a classic on the road a little longer by which ever means are available to you. I’m convinced you’ll take whatever means necessary to stave off the rot and maintain the structural integrity of that little GTI for a few more years to come.
If you’re concerned about moisture ingress, maybe try sealing each joint with fibreglass stranded filler, zinc weld-thru primer and seam-sealer. Just be aware that you’re effectively doubling the thickness of the metal, making the manipulation of any low or high spots afterwards that much more difficult
