Rannsachair
- Lochgilphead, Argyll, Republic of Scotland
and a fetish for Honda'sI have deficiencies in many areasFor example I tend to be obsessive
That is not a deficiency, now if you had said KTM or Ducati or old British Iron then.....and a fetish for Honda's![]()
That is not a deficiency, now if you had said KTM or Ducati or old British Iron then.....![]()
Or try mustard.Apparently low quality instant coffee is a little bit acidic & it helps to bring out the contrast
Try trimming off a few more thou of metal and knurling on very slow with a few drops of oil if the knurled pattern is out of sync ,Lubricant makes a big difference. The knurl dislodges bits of material from the stock and if you don't lubricate, they get stuck in the indents of the knurled part and the next time it gets to the teeth of the knurl it gets mashed. Lubricant washes all the crud away.
Not today but yesterday
I've lay down the main line for my workshop (which still to be demolished and build) , installed 2 lamps and 3 sockets.
Going to repair an handheld concrete mixer right now , because now I can (there wasn't any light)
It would be a great mess captured by picturesGet some pictures up![]()
Steam punk maybe?Made a genuine light sabre.View attachment 369903
Let see if I can sell it to a cosplayer and get money out of scrap ?
Assembly. Now we need to add a little chaos from the connecting pipes. The engineer who designed all this (dissimilar equipment) threw me a pig. In the dew point sensor, compression fittings with a thread size of 11 mm * 1.25 and a non-standard tube are used. All this will have to be redone, for Festo quick pneumatic connections. Tig welding and angle grinders, as always, will help out.A frame for a technological module for preparing clean air with a screw compressor + an additional 500-liter receiver is mounted + a huge dehumidifier, then a refrigeration module + humidity sensor + carbon filter. All with automatic condensate removal valves. The output of compressed air from the compressor is 3/4", from the latest filter the output is 1/4" ... and again the entrance to a separate reactor with a diameter of 18 mmThe designer was an entertainer. In metal, it turned out intricately. Dimensions 2000*800, steel pipe 80*40*2.5, 40*40, 40*20 and 4 wheels with bearings, 500 kg load capacity each.
Remove grease from black scale with acetone, spray with 2K epoxy primer and then paint with 2K Raptor Polyurethane Paint. Applying paint with a roller turns out economically and a good appearance.
View attachment 369115 View attachment 369116 View attachment 369117
