MattF
- South Yorkshire
I'd expect them to dry out and crack, not ideal for working with food?![]()
You lot are a tough crowd to please.
Yes, and?You lot are a tough crowd to please.![]()
You might be right, I'll post an update in a few months, or sooner if they're really shish.I'd expect them to dry out and crack, not ideal for working with food?![]()
lovely looking machine, are there modern equivalents or is it the proper made in Japan one you are after?You might be right, I'll post an update in a few months, or sooner if they're really shish.I make noodles often (and I can't afford the rolling machine I want) so they should see a lot of use.
Tut, tut....is that a guard off an angle grinder I spy there?![]()
Wouldn't proper industrial grade broom sticks have been cheaper???I went through my stock of round bar and considered 30mm stainless, that would do for hitting things.I also briefly considered Tufnol but ultimately there's better uses for such posh material.
Pine isn't ideal but it's cheap. I've wanted a really long one a few times, and also thought a short one could be handy, this way I can play with them for a few months, see what work and and make some from a more expensive hardwood if I feel the need.
Use a food safe oil https://www.amazon.co.uk/Pure-Mineral-Oil-Chopping-Pharmacopeia/dp/B0076YERWUYou might be right, I'll post an update in a few months, or sooner if they're really shish.I make noodles often (and I can't afford the rolling machine I want) so they should see a lot of use.
Probably, but then it's only 25mm, I thought about it.Wouldn't proper industrial grade broom sticks have been cheaper???
Oiling the wood ....oiled with olive oil after scrubbing off before natural air drying after use ?
ThanksYou're obsessed man !
