yes ,,, and that speaks volumes , lolAm I the only one which would be ballsy with a blow torch to try and get some heat into it?
May even go rude and tap a thread where the injector nozzle goes to get a bolt in there and then fill with proper carbon cleaner.
There’s a guy down our way has the kit to bolt the boring machine to Renault /vivaro engines to drill these out in situ. I would guess the beemer is similar, but would need it’s own jigs..Ruffian by name
Ruffian by nature.
But then again do remember a partner 1.6hdi which had a new glow plug for cylinder 1 slid inside a piece of pipe until the original snapped bit fired out. That was 2 weeks later along the a30.
And the amount of vivaro injectors snapped.
Got to love modern engines.
theres a guy over here does glow plugs ,,, cant remember the price but hes dear , and expects paid whether they come out or not ,,,, ive not yet got to watch him ,,, but I will at some point.There’s a guy down our way has the kit to bolt the boring machine to Renault /vivaro engines to drill these out in situ. I would guess the beemer is similar, but would need it’s own jigs..
Haven't you got it out yet?Thanks everyone for your valued input. Some great ideas here. I've updated some drawings which I'll attach below. My thoughts from some of the input here from @Kram and @James1979.
See what you think. Mag drill may be better but then would have to make the top end of the extension compatible with the ?Weldon? chuck? If I had a larger guide bush I don't see why a hand drill would not work...
View attachment 367655 View attachment 367656
even better if it had been soaking in injectorex ,,,Just an idle thought but what's to stop you trying to cut a M15 thread in the bit of injector that's stuck in there?
According to your Drg the stuck bits got an internal diameter of 14.2 mm which is about the tapping size. If you can get a tap started and cut a thread all the way down you might still be able to pull it out without drilling?
Got to be less risky than the drilling lark, and you never know, if you can get the tap started the twisting force might even break it free?
more details please how you went about this ,thanksI took a broken injector out of a head.
The injector was well stuck and the thread snapped off it.
It was taken to an "expert", who snapped a milling cutter in it.
I set about it with battery acid and a battery charger.
It removed the cutter and injector leaving the hole clean and lightly anodised.
It's basically anodising?more details please how you went about this ,thanks
I mentioned tapping it further up the thread as well.Just an idle thought but what's to stop you trying to cut a M15 thread in the bit of injector that's stuck in there?
Wrong way around, the anode/positive is eaten, cathode/negative grows with whatever metal is in solution. If the part to be eaten is stuck in the head that will be the anode and the cathode is the submerged wire. Use 12-20v, the steel should be eaten first. Using a bulb in series will make it very slow, a cheap buck/boost converter will give lots of control over itHead is cathode.
Bit of ali welding rod as anode.
