First time I've come across either of these processes, looks fantastic. Can you shed some light please as a quick Google didn't show the difference between the two?And these turned up earlier this week. Powder for the rototec and eutalloy torches.
I think @Brad93 has a thread on them somewhereFirst time I've come across either of these processes, looks fantastic. Can you shed some light please as a quick Google didn't show the difference between the two?
Thanks I'll go find that, sorry Brad.I think @Brad93 has a thread on them somewhere
Droopsnoot, what size beam compass are you looking for? I've got one hanging around doing nothing, made in Germany, 2 feet long with an extra 1 foot extension piece so you could do circles up to 6 foot diameter.
The rototec is for building up rotating components like shafts or wheels etc in a lathe. You spin the part at a given rpm/diameter. Spray the powder on at a 100° preheat. You then have a choice, some powders you leave in a cold state and some powders you can spray then fuse to the shaft making a metallurgical bond, much like brazing.Thanks I'll go find that, sorry Brad.
That's really impressive, thanks for the explanationThe rototec is for building up rotating components like shafts or wheels etc in a lathe. You spin the part at a given rpm/diameter. Spray the powder on at a 100° preheat. You then have a choice, some powders you leave in a cold state and some powders you can spray then fuse to the shaft making a metallurgical bond, much like brazing.
The cold powders ensure no shaft distortion or warping. Adhesion obviously isn't as strong as it relies on a micro bond between each droplet of powder and the part.
When you fuse them the powder the boron and silicon form a fluxing agent and you get a proper bond to the part.
The eutalloy process is primarily for hardfacing. But you can basically puddle weld with nickel powder. That is good for cast iron, tool steels, anything crack sensitive.
If you get your blink rate at the correct frequencies, the light stays onA timing light to play about with but it must be faulty as it keeps flashing when the engine is running
View attachment 366257View attachment 366258View attachment 366259
Today I acquired......a bit of peace and quiet in my jaw, and a gap in my upper set of teeth
glad it was just one to be honest6,7?
