Stick one end on the coarse grindstone ...loads of bright 3/4 inch long tailed sparks & it's high carbon steel.Cheers folks
I've only got one bit but it's quite long about 5 feet so can have a few attempts
Planning on trying to make a basic knife I can put and edge on them to razor sharp fine but have never made one before from scratch.
I thinking to use a stock removal method and then heat treat with my blower and brake drum forge using coal.
Not terribly worried about the look of it or corrosion resistance it isn't being used in a fancy kitchen.
@Screwdriver it appears they reccomended that type of use in the red advert I copied into the post , talking about reamers etc and about its hardness and toughness
@hotponyshoes , very good idea I atleast know the exact steel but may be hard to find out those parameters if they last traded in the 60s so will have a bit of research
Might end up ordering a steel but I do prefer to use what I have lying around and I like the history of this steel so worth a shot.
@Migmac Good to hear cheers
oking for some unneeded thicker leather
I could send you some veg tan blocking leather i get off cuts from work. You can put this stuff in warm water and mould it. Giz a pm if you want any.
Hmmm How stinky are your feetI'm just about to bin a pair of DeWalt riggers?
, Sounds like magnets probably got easier to post flat offcuts rather than boots that have already been formed around a shape guess? Appreciate the offerYes this was any free weekends and evenings to come out and do some wet sanding or handle glue , Good project to pluck away at and vert satisfying.Yesterday I was sharpening the Sabatier's carving knife , chefs knife , boning , filleting and veg blades on an old fashioned 8 inch x 10 mm bar chefs steel . It's 35 yrs old or more and is slightly smoothed as we are on our second set of Sabatier knives
I was thinking of buying a new quality steel as the old one is a single piece forging & seeing what sort of blade could be forged out of the old one as it's pretty hefty in the hand .. I think it might forge to 6 mm by 20 wide not sure of length but then cut it half and ground flatter then heat forged to the remaining part, thinking ( hopefully could give a usefull four inch by 12 mm bar to play with .
I'm not ready for this just yet as I've oodles of things to do of a greater priority to do first but now it's in print it's now on the Roundtuit list .![]()
Thats great mate well done. Giz a shout if you need anymore leatherWell I suppose this is probably the final installment in the total build
Big thanks to @magnet for helping out with this one much appreciated pal
Don't think I would make a good leather worker this took ages and isn't even neat
I did get a bit faster onto the end so will have a go at an axe sheath now I have a tiny idea what I'm doing
Started with 3mm thick leather
Then cut a rough template out around the knife allowing a inch and a half ish for room , this is then soaked in warm water to get it plyable , I was surprised how plyable it became very very soft so soft I managed to dent it with tissue paper on the end of the clamps whoops
Belt loop cut from an offcut , drilled holes.for sticking as it was a bit heavy for my awl it seemed
Don't think the stitching wins any awards but it's holding it good n tight
Same technique on the edge bevel but expect I had another bit of leather cut to fit between the fold to give it a bit of a gap for the knife blade to go into aswell as stopping the possibility of the threads being cut
And the finished product with some beeswax oil mix for finishing
Hahah Yes I think I bought the same kit lol kept bending the needles and stuff complete chinesium but ah well it does a job not too worried about this one for camping getting knocked about.My first one was worse but that went straight in the bin. I bought a stupidly cheap and nasty "leather kit" from some dodgy Chinaman with the view that I could try each part of the kit and see which bits I needed to replace with useable tools. So wnile most of the needles snapped(!) and half the weight/number of items are pointless "stamps" I do have almost useable tools tfor neatening up the edges which is where your sheath is most visually challenged. It is amazing how much a parallel line at the edge tidies up the visuals.
I have a peice of gound AISI Type 01 Tool steel (its a bit big 100 x 500 x 10) would this be a suitable material for knifemaking?
I can grind it to a suitable thickness but I don't know about the suitability of the material for a blade.10mm? That's a big knife!
Thank you for the infoIt's certainly a suitable material. O1 is often sold as "Gauge Plate" intended for making gauges and tooling in the workshop. It's Oil-Hardening (the "O" in O1 denotes Oil-hardening) and is relatively easy to Heat-Treat using backyard Heat-Treat methods. Because it needs a soak at Austenitizing temperature (800 degC or thereabouts) to get the Carbon properly into solution, it's not as easy to Heat-Treat as some of the other Carbon steels (1084 is probably the most-recommended starter steel, largely because it doesn't really need a soak at Austenitizing temperature). In typical knife blade thicknesses, a 5-10 minute soak at Austenitizing temperature tends to be needed to get the best out of O1 and few backyard setups have tight enough temperature control to do this easily.
10mm is thick for knives, but O1 is forgeable (with careful attention to temperatures) if you have heating-and-beating facilities. It can Air-Harden, particularly in thin sections, so you need to be aware of this.
Oh, it’s about as easy as it gets. Very forgiving material in my experience. Not done any ten mil though!I can grind it to a suitable thickness but I don't know about the suitability of the material for a blade.
