The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
To late .Today I acquired ......
Edit: Told my Wife you guys get first option on all my toys.
I have arranged for a shipping container or 4.
Thank you Mr. Vark, I knew we could always rely on you to be on the ball !To late .
Thanks for the reply, yeah feeling quite rough. Hope you are doing better ?Laugh only for the toys comment. Hope the covid doesn't make you feel too rough!
It is ok.Thank you Mr. Vark, I knew we could always rely on you to be on the ball !![]()
I am feeling quite good today cheers, my sister in law and her husband came to visit and cheered me up somewhatThanks for the reply, yeah feeling quite rough. Hope you are doing better ?
Found this at the recycle today, got this and a box of heavy M14 bolts and M8 long coach bolts, brand new AssaAboly 5 lever deadlock in the box for £5.
But what is it?
Bugger, didn't see the barrel!Beer tap
Beer/Keg tap.Found this at the recycle today, got this and a box of heavy M14 bolts and M8 long coach bolts, brand new AssaAboly 5 lever deadlock in the box for £5.
But what is it?
Some new ones are made from Beech as well.New ones are made of plastic/nylon, the brass ones are used for decoration it seems.
Don't use a lump hammer.They are fun inserting. Place on bung in barrel and give them one hard and confident blow from a decent lump hammer. If all is well the bung goes in the barrel and the tap seals OK. If not you hit your thumb, tap goes all over the place and you loose a firkin of beer !
Remember to close the tap first !!!
It's similar here - if a welded repair is required for MOT, when you present the car for re-test the welds must be visible. If it's a patch to an existing panel - for example a sill - then it must be seam welded around all edges. Oh, and suspension components cannot be welded to pass a re-test, so if my subframe has a hole in it, it either needs welding up before the test, or replacing if it fails. Or it was, last time I had to re-present a car after rust repair.Our rules are like this: If significant welding work is to be carried out on the cab for the TÜV/MOT, this must afterwards be completely visible during the inspection (spot welds at least every 25mm), only a light rust protection is permissible - here red-brown rust protection primer.
