Trevorleach
- UK
how much do they cost? near me a remap is £130
I think you will find there are remaps then there are remaps.
65 Mpg I got out of my 2.0 litre passat estate going to Bristol Airport yesterday.
Good enough for me.....
And so many do, most remaps and chips are bought by the lead foot brigade. I know of many that have gone bang, driven carefully they are ok but not may folk that have these things chipped or remapped do that.
Bob
Some 'tuners' just trick you into thinking they've improved things.
Common tricks are to remove the lower gear torque limiting. To improve driveability, modern engines limit torque in lower gears to avoid wheel spinning/losing control under hard acceleration. Removing/increasing the torque produced, gives the impression you have more power, because you can now spin the wheels easier in lower gears.
Then there is simply fiddling with the throttle pedal mapping, so less throttle pedal gives more response. Gives the impression the engine is producing more power, as you don't have the press the accelerator as far.
the tuners who don;t really know what they're doing don't do anything at all
the pay for access to maps made by people who do know what they're doing, so they download your map, unload that to the web, then they're given a replacement map they download from the web and then upload that to your car
Can only image they spoof canbus transmissions.
I'd rather get it done professionally and have a place to return when it all goes tits up.
Personally I think the manufacturers probably know best
My Mondeo 1.6 turbo diesel has a huge 'hole' in the power delivery. It has enough torque to pull away in 1st gear without even using the throttle, but then from about 1100 rpm to 1900 it is a total slug. I assume the turbo starts giving positive boost at 1900, but it seems almost too much like the fuelling switches over and away it goes.Any modern common rail turbo diesel vehicle I've driven in the last ten years gos plenty fast enough for me.
Last thing I'd do is try to squeeze more power out of it at the risk of compromising its reliability.
That's the anti-stall. I'm told (by a friend who is a Ford Diesel Calibration engineer) that it's almost impossible to stall a modern diesel as long as you *don't* use the throttle.It has enough torque to pull away in 1st gear without even using the throttle,
Manufacturers have to consider emissions, reliability, warranty, noise, drivability and efficiency.
Remappers don't have to care about any of that and the plug in boxes (the ones that aren't just a scam, consisting of just a box with flashy lights) are worse still.
If manufacturers franchises will sell you a set of car mats for £500 and a service without an oil change for £300 - software updates for to overcome their faulty code from the factory - for £hundreds at a time. They would sell you performance maps - if it was good idea - it would be easy income stream for them - they have all the code.
There will be hidden downsides. It is up to you to decide if they matter to you.
Oh, and you will have no idea what they are. Which makes the decision harder.
I thought it was just the governor, opening the throttle as such, common to all diesels?That's the anti-stall. I'm told (by a friend who is a Ford Diesel Calibration engineer) that it's almost impossible to stall a modern diesel as long as you *don't* use the throttle.
It's quite useful in this countries never ending traffic, the car will dribble along slowly in either 1st or 2nd gear keeping a steady speed with no throttle input.
