That's a seriously good box of useful bits - totally enviousSpotted a tin of old nuts and bolts outside a house for scrap, it would have been rude not to take them away.View attachment 361476
The person who threw that box out is going to need one of those bolts next weekSpotted a tin of old nuts and bolts outside a house for scrap, it would have been rude not to take them away.View attachment 361476
These guys have a member who lives & breathes Atlas/ craftsman lathes .. he has taken a lot of time to develop the craftsman lathe section join and all will be revealedATLAS, CRAFTSMAN, COMPANION, DUNLAP & AA
Discuss any issues dealing with Atlas & Atlas-Clausing lathes, drill presses, mills, etc. in this forum.www.hobby-machinist.com
You do have the basics but seem to have over complicated things by your thinking .
Set the gears to the correct metric thread feed .
Using a clamp on saddle stop at the chuck end to always bring the unclamped saddle back to the same position by rotating the lathe backwards by hand will always bring the TDI back to a ready to start point every time ... note the TDI position orput a spot of your pink nail varnish on it to read to the start point .
Run the thread off the RH end of the stock . Disengage the half nuts sharpish , stop the lathe , back off the cross slide & cutter to clear the major thread thread by a few thou , hand wind pullies back wards so the saddle is fully to the left on to the stop . Check the TDI is in the right position adjust if needed , advance the cutter in a few thou , engage the half nut fully , start the lathe .
As the lathe is in slow rpm there is no conflict about taking off a few thou on start up .
If you undercut the left hand end thread max diameter by the thread depth plus say 4 thou it will give you an under cut space space to get your tool in without having a tear out of metal .
A broken ride on mower blade spindle assembly, just what I didnt need! Its off an American Roper so lets hope it crosses over to something else in the UK
First place i looked.. 4 tiny washersWhat's in the card box?![]()
Yes you are right , I made a mucking fuddle in the neck top computer department whilst trying to type it out , leave the half nuts connected and wind the saddle back to the stop then check the TDI alignment .Been a member there for years, the link just takes me to the forum section, not a specific thread.
Using a bed stop will not work. Period. If you disconnect the half nut, the saddle is no longer correctly phased with the lead screw. I am not overthinking this or over complicating it. Looking at the basic fact of the matter, if you wind the saddle back to a stop, it will not return to the same phase relationship to the lead screw unless it happens to be an even multiple of 127 turns of the TDI away from where it stopped.
You can always ask the guys on the welding site for worked knowledge rather than trawl through thousands of posts looking for things , they've been very helpful to me over the years .
Yes you can.Cant beat a tin of things, everybody should have one
Bob
Yes you can.
2 tins of things.
RTFM ) you can see that it is easily done , so it's a win all round .Do not manually wind the saddle(!)
Power the lathe backwards and as the TDI starts turning backwards, re-engage the half nut at the mark. Note because you stopped the lathe very quickly after disengaging the half nut, the TDI has only moved a small amount past its mark. The half nut is of course in the exact same phase as if you hadn't disengaged it SO LONG AS YOU DON"T MOVE THE SADDLE MANUALLY WHILE IT IS DISENGAGED.
If the saddle moves at all while not connected via the half nut, the relationship of its position wrt the thread is lost.
shocking price
I guess its better than hanging them on a tree.My driving the saddle back is done by hand by turning the over head pulley backwards as I don't have complex reverse gearing on it so it's dead easy to get it back the the precise point you started off at every time by meeting the edge of the saddle with a bed stop clamp device .
What is good though is that you initially said it was impossible , now you've had a chance to read the manuals (RTFM ) you can see that it is easily done , so it's a win all round .
What's with the abrasive response?No. Not at all. I have no idea what you are trying to say here. The process as you describe it is in fact impossible for all he reasons I have stated. You cannot move the saddle manually with the half nut disengaged and still remain in phase with your thread.
I should just leave it there really because I have said everything A THOUSAND TIMES now and you keep coming back telling me I’m wrong. You are completely wrong, what you suggest is impossible.
There is one method where the half nut is briefly disengaged WITHOUT MOVING THE SADDLE, which actually, I picked up from Abom79. I don’t use that technique, I just hit the stop and reverse the machine.
As I have said a thousand times you cannot move the saddle by hand, by kicking it, yanking on a pulley or whatever other excuse you want to think up. Running the saddle back to a stop is pointless, it will not work for the reasons stated earlier. If you want to keep pretending you’re somehow right, knock yourself out, I am experiencing sense of humour failure and have no more interest in trying to explain it. If you can’t understand it now, I give up.
