As I see it, the only problem with the engines was fuel crud blocking the filters.The only thing I was thinking about whilst reading through is will you get your money back
Also but I could have missed it. … what about engine after it’s been standing for a long time
 )The engines are both running fine, I've done about 40 hours on them now and because of the old diesel I'm planning to change the filters about every 40 hours of running. She has a quarter of a tank left in her then I might open the tank and see how bad it is.The only thing I was thinking about whilst reading through is will you get your money back
I should really practice my soldering
In most twin engine boats yes.Does one prop run in the opposite direction to the other?
Surely the easiest thing to do would be to crank an engine and observe the prop rotation?Yes, was quite a discussion when the props got refitted to make sure they were on the right sides as I didn't have clear pictures and neither did the guy I paid to remove and refit them.
Have to be careful when the boat is on stands.Surely the easiest thing to do would be to crank an engine and observe the prop rotation?
