Agroshield
...limited to 3/8in (10mm) capacity. Anyone know of a "Plan B"?
Plan 'A' is to use the drill press in the manner in which it was designed.
There is a good reason that J2 stops at 10mm capacity: because that is the capacity (torque) a taper of that size/dimensions can handle without popping loose.
I cannot find a 30mm 1/4" drive impact socket for a similar reason.
This is the one I should have put, it is the cheaper option.
