W.olly
- Radcliffe, Manchester
I went to work today felt sick, felt as rough as death warmed up infact, so went back to bed then got up at dinner and played out
( honestly i was not well )
So i though an easy job i pressure tested the fuel tank,
Found a of cut of 50mm bar to bung the end of the filler opening with the help of some radiator hose.
Then got my cheap tyre inflator, cut the tyre vavle adaptor off and connected that to the fuel off take. Bunged up the breather with a bit of water pipe and bar
And hey presto, lets go blow myself up as i cant measure as low as 5psi as it starts at that. so took a guess lol. Just put enough in so a little less that 5psi which will be enough for this.
1/4 filled with water so easier to see low down leaks
All fitted seem ok so now ill leave it for a few days and see if the tank gets an softer if you know what i mean, not in tension and any wet spots anywhere.
BTW, its not stainless steel, its Aluminum tank. wondered why it was so light ha ha
