- UK
An EICR has flagged up a lack of RCD protection on a board. Board is plastic and probably pointless trying to obtain RCBOs for it, so may as well fit a new board.
There's some minor bits to attend to elsewhere which i'll sort and I may as well fit the board. A proper spark will check, test and sign off.
I was looking at buying the bits below. That should be it? RCBOs are different values, but i've just added four the same to the basket for pricing purposes.
Spark says don't bother with AFDD or SPD.
£90 ish for a populated board seems reasonable.
Edit - Add some grommet strip around the opening in the back of the board as well as some intumescent mastic...and some DNO fuse seals....
That it?
That it?
