No reason at all you can’t get that and more if you’re a decent driverGot 90000 out of our VW Tiguan front discs.
wot a load of ****** it it passes its test every year theirs nowt wrongI change my brake fluid every 2 years, see no reason not to, brake fluid is cheap as Chips and opening the nipples (ooh matron) stops them corroding shut.did 100 thousand miles on my combo van changed the front disks once and 2 lots of pads rear disks lasted on originals . go to the main stealers and they want to change the lot at 40 thousand and flush your brake pipes outwot a load of ****** it it passes its test every year theirs nowt wrong
id do my own only if i had to like a leak on a cylinder if its not broke dont fix itI change my brake fluid every 2 years, see no reason not to, brake fluid is cheap as Chips and opening the nipples (ooh matron) stops them corroding shut.
But then I’m not paying someone to do it.
take the lead out of her high heelsMy old Skoda Superb did well over 100k on a set of EuroCarParts Eicher discs and pads. All depends on the driver and the type of usage. Mine was a motorway hack and I’m not hard on brakes anyway.
SWMBO, on the other hand, yeah she can burn through big old Brembos on a supercharged Jag in 6k miles. Back tyres were 3k.
Sporty girl!My old Skoda Superb did well over 100k on a set of EuroCarParts Eicher discs and pads. All depends on the driver and the type of usage. Mine was a motorway hack and I’m not hard on brakes anyway.
Fluid absorbs water - corrodes stuff from inside. Considerably reduces it's effectiveness by reducing boiling point. Now, maybe if you drive like Miss Daisy's geriatric grandad on a slow day, you might not think that will bother you - but a long descent could cause issues.id do my own only if i had to like a leak on a cylinder if its not broke dont fix it![]()
i hardly drive slow im lucky to get over 80 thou out of a vehicle and pull the sh..it out of themFluid absorbs water - corrodes stuff from inside. Considerably reduces it's effectiveness by reducing boiling point. Now, maybe if you drive like Miss Daisy's geriatric grandad on a slow day, you might not think that will bother you - but a long descent could cause issues.
use the gears to decent long hills along with braking .use ferodo pads which are harder than standard crap that overheat and fade when the disks get hot. there not so good till you warm them upI was thinking of putting the good one back in probably get another 2000 milesThe state of those pads. Nowt to be proud of
Well it's a point, but the descent would have to be from space....Fluid absorbs water - corrodes stuff from inside. Considerably reduces it's effectiveness by reducing boiling point. Now, maybe if you drive like Miss Daisy's geriatric grandad on a slow day, you might not think that will bother you - but a long descent could cause issues.
Maintenance only to pass MOT is a bit . . . "silly" is about as tactful as I can get.
